First couple of knives I ever made were similar to your situation. Here's what I did. I used the rest on the grinder, got a small piece of 1/4" x3/4x3/4 steel and a pair of vise grips. By clampling the 1/4" steel to the grinder rest with the vice grips (very tight, like you have to use both hands to close them) I was able to create a "stop" that I could consistently run the spine of my blade against. By this method I was able to get a very nice hollow grind which matched on both sides. A couple of caveats; the motor can get in the way if this is your typical two wheel grinder and your blade is long, don't ever ever take the vicegrips off or you will loose your repeatability, the vice grips must be tight so they don't vibrate loose or move during the course of the grind, aluminum works better for the stop because it doesn't scratch the spine of the blade as bad. The final comment is one of safety. You need to adjust the rest and setup to keep your bevel just slightly above the tangential line of the grinding wheel. If you get below this "center" you will jam the blade between the rest and the wheel. Since the wheel is moving in a downward direction you will get all kinds of torque, screw up your blade, create a projectile, jack up your wheel and create a really bad day for yourself.
If you can handle all of that, good luck and happy grinding.
P.S. My first knife was thick cause I wanted it to be "tough". After hours of my nose to the grindstone I started to get frustrated. If you intend to do the whole thing by stock removal, save yourself some time and go thinner on the blanks. It will save you much aggravation and get you to that completed knife faster, which is important to boost moral and keep you interested in knifemaking. It can be easy to loose steam when you first start out, especially if the process of making a knife is frustrating. I would recommend keeping the first couple of knives small and no thicker than 3/16".
