- Jul 24, 2002
Best initial sharpener is the Spyderco Sharpmaker, makes touch up jobs real easy, just takes a bit of practice and works well on recurved blades and serrations. An EdgePro makes reprofiling jobs easy, and will allow you much more flexibility in adjusting edges to your own specifications, but is $$$. These are pre-assembled sharpening systems, of course, but you can do well with something as simple as sandpaper on a glass plate. Just that it'll take a lot more practice.
Every lockback I've owned has had a small amount of play, to varying degrees, but it doesn't affect the lockup unless it's particularly significant. My Manix has maybe a millimeter of tip movement when I push down really hard on the handle. Otherwise, you won't notice it. As noted, it really isn't a problem and may in fact be beneficial as the lock up won't be as easily compromised when contaminated.
