1) For heat treat; like others have said 'send out'. Alternatively, you could try using cutting torches and experiment abit. That is how I started out and had some good success with 01 and even 440C, before buying a Paragon furnace.
2) Drill out the holes for the guard, pommel and for the rivets that will hold the handle scales together prior to HT. Think of a full tang knife handle as a 'sandwich of metal and wood' that is held together by rivets, pins and adhesives. Simply match the drill size to your pin sizes (diameters). Drill out, then pin together along with the glue.
If you search around the forum you will find loads of info on how to build handles, heat treat, blade finishing, and sheathing. Basically everything you need to know. If you don't find it here, just keep asking the membership questions and we will try to help you out.
Knifemaking is a satisfying and sometimes addicting hobby. A great way to let your creativity flow.
