- Aug 22, 2016
Hey guys,
Got some .125 thick 52100 stock and plan on trying my first kitchen knives. Here is a pic of my design, the blade is 6.5" long and the tang that will be in the handle is 2 7/8" long. Plan on using Gflex epoxy and throwing 1 or 2 1/8" 416 stainless pins in there that will not be peend. Handle material will probably be some walnut/cherry scrap from old window panes, I have used the walnut for scales before and after a month or so of sanding and applying a Watco tung finish it is really pretty (6 coats of oil with 12 hour dry time, 3 week cure, finish with furniture wax). My question is will the tang this length be enough to hold the handle in securely or should I cut out a longer tang? After looking at the width of the walnut 11/16" I might find a different wood for the handle, something thicker and save this for scales. I planned on using 2 different kinds of wood, 1 for the handle and 1 for a "ferrule", should I use the epoxy to glue these 2 pieces together as well or just gorilla glue? I will also use 1/2" dowels in the middle with a slit cut in it to house the tang.
I planned on flat grinding the blade from spine to edge until the spine was at a decent thinness then starting a secondary bevel and adding slight convex on a slack belt after heat treat (I'd like to grind as much as possible before since I only have a 1x30)
Here is a little d2 blade I was playing around with to practice bevel grinding, it is the first one I have ever done(done a few chisel grinds, first double bevel). Still needs some work but I think I'll finish it after HT, edge is a little less than dimes thickness.
All the rough patches will get smoothed out, just had to finish because my baby woke up and wanted out of his crib.
Any advice is appreciated and thank you for taking the time to read this.
-Trey
-Trey
