You think a chosera is close to the superstones at 3k?
The Chosera 3k and SS 3k are miles apart. The SS are some of the softest stones while the Chosera are some of the hardest.
The 400 Chosera is one of the fastest cutting and smoothest grinding stones available. Said to be faster than a Shapton 120 while leaving a fine scratch pattern easily removed by any 1k.
what is your criteria for hardness?
The Chosera produces a lot more mud than the super stone, that means that the binder is pretty easy to break up, which is a characteristic of a soft stone.
Super stones are hard stones in that regard and Chosera are not. It is exactly the same as with naturals, more specifically Japanese naturals, Japanese synthetics are made to some extent to mimic natural stones. Hard naturals release almost no particles , soft release a lot.
How does it work then?That's not exactly how it works, actually, mostly wrong.
softness is related to slurry release not how the stone feels. Soft stones are usually low grit stones, and this is no a surprise, as more slurry released in the mud means faster cutting action. To polish the bevels successfully one has to use harder stones, that is the purpose of higher grits, they get increasingly less willing to release particles in the slurry thus providing more polishing.Stone hardness is generally gauged by how much or how little gouge resistance a stone has. In the case of the Chosera the overall hardness is very high making them wear slowly and be very resistant to gouging. The SS are on the opposite end of the spectrum, their softness often described as chalky or clay like.
I refer to slurry from the stone not swarf, one is stone abrasive the other is metal particles from the steel, pretty easy to tell the difference.The mud you refer to on the Chosera stones is mainly swarf from the blade with a very fine bit of stone mixed in. Being hard and slow to wear the Chosera stones create more of a swarf-mud.
That has to do with the binder, it is resin by the way, but also tells you that the stone is not too willing to release abrasives, which is what harder stones do.Above 1k the stones load heavily collecting much of the removed metal on the surface which then must be lapped off.
Not really, there is no synthetic counter part to natural stones. Of coarse we are talking about Japanese natural stones vs synthetic stones (most of them Japanese made). Natural stones slurry works in a way that can't be duplicated with synthetic abrasives, not yet at least. The closest to naturals are stones with natural and synthetic mix, or two different size abrasivesNatural stones are a whole different ball game, the Chosera stones would be the best synthetic comparison
