NIB a Spyderco ATR - BCN
Feedback: +26 / =0 / -0
Spyderco ATR - BCN . Always ready. Spyderco’s stainless steel A.T.R (At The Ready) comes well-heeled with high-tech tactical features and is fully coated in non-reflective black Carbon Nitride. Drilled out of the stainless handle and clip are a series of holes. The holes lessen the folder’s weight and make position spots for the thumb and fingers to index the knife into different grip-holds. The integral Compression Lock, locks open the blade by using part of the handle scale using fewer moving and wearable parts. Tip to tang the VG-10 blade is 3- 7/16 inches (87mm) with a snub-nose that cants upward becoming thicker at the tip for extreme and strenuous use. The hollow-ground blade has an additional dagger-grind down its center effectively balancing both sides while simultaneously enhancing tip strength. Unlike a traditionally ground dagger, the spine is non-sharpened. Positioned above the Spyderco Round Hole, a Cobra HoodTM juts a flange of steel out, over either side of the blade, guiding the thumb into position over the hole for rapid, by-feel, deployment. While you cut, the Cobra Hood creates a textured seat where your thumb finds slip-resistant purchase. Pre-drilled clip holes create the option of left or right-handed use and position the folder tip-up in the pocket. Overall length is 8- 7/16 inches (213mm), overall weight is 4- 3/4 ounces (135 g). New In Box, never carried, original edge.
Will trade for other Spyderco's ...... such as:
Spyderco Kiwi Carbon Fiber ~ C75CF
Spyderco Sage ~ C123
Spyderco Military Black Blade ~ C36GBK PE
Spyderco Military Digital Camoflauge G-10 ~ C36GCMO
Spyderco Military G-10 ~ C36G PE
Spyderco Para Military Foliage Green ~ C81FG PE
Spyderco Para-Military Black Blade ~ C81GBK PE
Spyderco Para-Military Digital Camoflauge G-10 ~ C81GCMO PE
Spyderco Para-Military G-10 ~ C81G PE
Spyderco Police3 G-10 ~ C07G3 PE
Spyderco Barong by Ed Schempp ~ C124
Original Dyad C44
Spyderco J.D. Smith ~ C58G
Spyderco Khukuri by Ed Schempp ~ C125
