NIB - Benchmade 930BK + Spyderco C10PSGRWBK
Feedback: +26 / =0 / -0
Traded
Benchmade Osborne Kulgera Knife Black Blade 930BK $150 shipped to a USA address
Another great Warren Osborne design produced by one of the best American knife companies.
BENCHMADE - BM930BK - Kulgra™ - Osborne Design
The 930 Kulgera™ is sleek, comfortable and an all-around handful of beautiful utility. CNC Milled black/blue layered G10 handle scales, BP-1 coated liners, black nickel hardware and clip, plus super tough S30V blade steel. Born in the outback, the Kulgera brings form and function together seamlessly.
* Overall Slim Profile
* One-Hand Ambidextrous Function
* Fully Adjustable Blade Pivot
* Lightweight Everyday Carry
* Country of origin: USA
* Blade Length: 3.60"
* Blade Thickness: 0.115"
* Blade Material: BLACK - S30V Premium Stainless Steel
* Blade Hardness: 58-60HRC
* Blade Style: Modified Drop-Point
* Weight: 3.00oz.
* Clip: Tip Up, Reversible, Silver Split-Arrow
* Lock Mechanism: AXIS®*
* Overall Length: 8.00"
* Closed Length: 4.40"
* Limited Lifetime Warranty
*AXIS® A patented Benchmade exclusive, AXIS has been turning heads and winning fans ever since its introduction. A 100-percent ambidextrous design, AXIS gets its function from a small, hardened steel bar which rides forward and back in a slot machined into both steel liners. The bar extends to both sides of the knife, spanning the liners and positioned over the rear of the blade. It engages a ramped, tang portion of the knife blade when it is opened. Two omega style springs, one on each liner, give the locking bar it’s inertia to engage the knife tang, and as a result the tang is wedged solidly between a sizable stop pin and the AXIS bar itself
Traded
Spyderco USN Endura 4
Spyderco's participation on the Usual Suspect Network forum led to the creation of a very special, one of a kind knife, the Spyderco USN Endura4 in Toxic Green. This USN Endura4 is not only Toxic, but includes some of the most popular attributes found in the Endura4 lineup.
Introduction of the Endura with Emerson's opening feature; combining all that’s functional and performance-based in a Spyderco folder with the blade-opening feature made popular and patented by Ernest Emerson of Emerson Knives. The Emerson opening feature is a hook curving out the top of the knife’s blade. When removing the knife from a front pocket it catches the pocket’s edge quickly opening the knife blade ready to use. The knife can also be taken out of the pocket without engaging the opening feature by pulling it straight up and out with your fingers on top of the closed blade.
The USN Endura also features all screw construction making cleaning and adjusting easier. Toxic Green fiberglass reinforced nylon handles are molded with Bi-Directional Texturing® for traction and improved ergonomics. Inside the handle dual skeletonized stainless steel liners strengthen the knife without additional weight and create an anchor for external and internal components to attach through for more sturdiness and rigidity.
The flat saber-ground CombinationEdge VG-10 blade is non-reflective, coated with black titanium carbonitride; includes a strong tip and larger 13mm opening hole. The front of the blade features the Usual Suspects logo. Added to the blade’s spine is slip resistant jimping. Phosphor bronze washers smooth out the open/close action and the clip is a four-way tip-up, tip-down, left- or right-handed clip.
ONLY 600 were produced
Model # C10PSGRWBK
New in Box
TRADE FOR: PE Spyderco's, PE Benchmade's, Peter Atwood tools, Leatherman Sideclip, Flair, Surefire LED's, BM 610 Rukus PE.
