- Nov 13, 2004
Will trade for Atwood tools
NIB Emerson A100-BT
Specifications:
Handles: Black G-10
Blade: 154 CM Premium Blade Steel
Finish: Black
Overall Length: 8.4 in.
Blade Length: 3.6 in.
Blade Thickness: .125 in.
Hardness: 57-59 RC
Weight: 4.8 oz.
NIB Emerson mini - A100-BT
Handles
Black G-10 epoxy / glass laminate
Aerospace grade Titanium
Blade 154 CM
Finish Black
Grind
Conventional V Grind
Overall Length 7.2 in.
Blade Length 3.0 in.
Blade Thickness .125 in.
Hardness 57-59 RC
Weight 3.4 oz
NIB Victorinox Swisstool "S" Black Oxide #53815
SwissTool Spirit S now with two blades. A standard spear point blade replaces the scissors on this model which still packs 27 features in an ergonomic, rugged, lightweight design. Comes in a nylon belt pouch. Needle Nose Pliers, Screwdriver (2 mm), Screwdriver (3 mm), Wire Cutter (for up to a hardness of 40 hrc), Bottle Opener, Screwdriver (6 mm), Strong Crate Opener, Combi-Edge Blade, Large Blade, Metal File, Metal Saw, Wood Saw, Reamer, Phillips Screwdriver, Chisel/Scraper, Isolation Length Cutter, Wire Bender, Wire Stripper, Wire Scraper/Round Cutter, Can Opener, Multi-Purpose Hook, Nylon Pouch, Coupling for Corkscrew, Hard Wire Cutter, Lanyard Hole, Ten Individual Springs, Lock Release. Life time warranty - MADE IN SWITZERLAND.
NEW Leatherman FLAIR with leather sheath - NO BOX
NIB Emerson A100-BT
Specifications:
Handles: Black G-10
Finish: Black
Hardness: 57-59 RC
Weight: 4.8 oz.
Handles
Blade 154 CM
Finish Black
Grind
Hardness 57-59 RC
Weight 3.4 oz
