- Nov 13, 2004
#1 NIB Leatherman Charge XTi
Traded
For the most ambitious outdoorsman and for the most demanding professional, the Charge XTi is the ultimate in multi-tool performance. The best materials - like 154CM knife steel and titanium handles, plus added strength and versatility make the Charge XTi the new standard for excellence in multi-tools.
* 154CM Clip-point Knife
* Serrated knife with Cutting Hook
* Needlenose Pliers
* Regular Pliers
* Wire Cutters
* Hard-wire Cutters
* Wire Stripper
* Wire Crimper
* Two Large Bit Drivers
* Small Bit Driver
* Wood/Metal File
* Diamond-Coated File
* Saw
* Bottle Opener
* Can Opener
* 8 in | 19 cm Ruler
* INCLUDED BITS: Phillips and Flat Tip Eyeglasses Screwdriver Bit, Hex 5/32" and 9/64" Bit, Hex 1/8" and 7/64" Bit, Hex 3/32" and 5/64" Bit, Hex 1/16" and .050 Bit, Square Drive #2 and #3 Bit, Screwdriver 1/8" and Torx #15 Bit, Phillips #1-2 and 3/16" Screwdriver Bit, Phillips #1 and #2 Bit, Screwdrivers 1/4" and 3/16" Bit
* Titanium Handles
* Stainless Steel Body
* Fixed Lanyard Ring
* Quick-Release Lanyard Ring
* Removable Pocket Clip
* Sheath
* 25-year Warranty
* 4 in | 10 cm (closed)
* 8.3 oz | 235 g
#2. NIB SOG Pocket PowerPlier Deluxe #S45 shipped to USA address
Traded
SOG's Deluxe Pocket PowerPlier is packed with essential tools that include pliers/grippers, wire cutters, partially serrated blade, small/large screwdrivers, Phillips screwdriver, 1/4-inch socket drive, medium screwdriver, three-sided file, can opener, bottle opener, awl, rulers, lanyard and heavy duty leather pouch.
Exclusive interlocking gears are the driving force behind SOG's renowned PowerPlier Series. They allow these amazing multi-tools to be opened with a one-handed flip of the wrist and also generates Compound Leverage action that doubles the pliers force with one-time the hand pressure. These gears also allow the pliers to be easily flipped open with one hand so your tool is ready to act quickly.
#3. NIB - Victorinox Swiss Army SwissTool Spirit "S" Oxidized Black #53815
Traded
Introducing the SwissTool Spirit S now with two blades. Our standard spear point blade and serrated / combination blade - 1. Needle Nose Pliers, 2. Screwdriver (2 mm), 3. Screwdriver (3 mm), 4. Wire Cutter, 5. Wire Cutter (for up to a hardness of 40 hrc), 6. Bottle Opener, 7. Screwdriver (6 mm), 8. Strong Crate Opener, 9. Combi-Edge Blade, 10. Large Blade, 11. Metal File, 12. Metal Saw, 13. Wood Saw, 14. Reamer, 15. Phillips Screwdriver, 16. Chisel/Scraper, 17. Isolation Length Cutter, 18. Wire Bender, 19. Wire Stripper, 20. Wire Scraper/Round Cutter, 21. Can Opener, 22. Multi-Purpose Hook, 23. Leather Pouch, 24. Coupling for Corkscrew, 25. Hard Wire Cutter, 26. Lanyard Hole, and 27. Ten Individual Springs. one-step access from the outside of the handle without opening the pliers; no clumping - individual springs hold other tools in place; and lock and release - the tools lock into place when opened. To close, simply slide the release button and fold the tool away. Also comes with an attractive and useful belt pouch.
#4. NEW - Atwwod STEEL - G3 Prybaby with Stone Aged™ finish. Traded
#5. NIB Leatherman Mini-Tool
NEW IN BOX -Leatherman Mini-Tool. . Includes NEW nylon sheath and printed users guide.
Traded
The Mini-Tool is the world's smallest multipurpose tool - standard brushed stainless finish - with full-size, full-strength pliers. Our unique folding handle design makes both comfort and small size possible. Slip it into your jeans pocket or wear it with the nylon belt sheath.
* Clip-point Knife
* Needlenose Pliers
* Regular Pliers
* Wire Cutters
* Hard-wire Cutters
* Screwdriver 1/4"
* Wood/Metal File
* Bottle Opener
* Can Opener
* Ruler
TRADE for a NIB Spyderco PE's
Traded
* Needlenose Pliers
* Regular Pliers
* Wire Cutters
* Hard-wire Cutters
* Wire Stripper
* Wire Crimper
* Small Bit Driver
* Wood/Metal File
* Saw
* Bottle Opener
* Can Opener
* Titanium Handles
* Sheath
* 25-year Warranty
* 8.3 oz | 235 g
Traded
Traded
Traded
* Clip-point Knife
* Needlenose Pliers
* Regular Pliers
* Wire Cutters
* Hard-wire Cutters
* Screwdriver 1/4"
* Wood/Metal File
* Bottle Opener
* Can Opener
* Ruler
