- Nov 13, 2004
Spydercos stainless steel A.T.R (At The Ready) comes well-heeled with high-tech tactical features and is fully coated in non-reflective Black Carbon Nitride. Drilled out of the stainless handle and clip are a series of holes. The holes lessen the folders weight and make position spots for the thumb and fingers to index the knife into different grip-holds. The integral Compression Lock, locks open the blade by using part of the handle scale using fewer moving and wearable parts. Tip to tang the blade with a snub-nose that cants upward becoming thicker at the tip for extreme and strenuous use. The hollow-ground blade has an additional dagger-grind down its center effectively balancing both sides while simultaneously enhancing tip strength. Unlike a traditionally ground dagger, the spine is non-sharpened. Positioned above the Spyderco Round Hole, a Cobra Hood juts a flange of steel out, over either side of the blade, guiding the thumb into position over the hole for rapid, by-feel, deployment. While you cut, the Cobra Hood creates a textured seat where your thumb finds slip-resistant purchase.
SPECIFICATIONS:
Blade Length: 3 7/16''
Length Closed: 5''
Overall Length: 8 1/2''
Weight: 5.4 oz.
Blade Style: Modified Clip Point
Blade Finish: Black TiN
Edge: Serrated
Blade Steel: VG-10
Rockwell Hardness: 59-61
Locking Mechanism: Compression Lock
Handle Material: Stainless Steel
Liners: Stainless Steel
Fittings: Stainless Steel
Pocket Clip: R/H or L/H, Tip Up
Country of Origin: USA
TRADE: NIB Leatherman Charge TTi or NIB PE Spyderco folders
