- Feb 4, 1999
If you want to etch using ferric chloride, first cut it one part FC to 3 parts water. Warm solution works better than cold. I etch my 1084 blades for less than 5 minutes. Use steel wool after the etch to remove crud and mellow out the finish a bit. Need to have at least a 600 grit finish. In the right light you should be able to see a temper line at 600 grit. Use wet/dry sandpaper with lots of water. A relatively light etch like I di is easily removeable with a bit of sanding at 600 grit.
Dr. Steve Agocs
http://www.geocities.com/Chiro75/frames.html
agocs_s@hotmail.com
Dr. Steve Agocs
agocs_s@hotmail.com
