Maybe it's sole purpose is to make the knife really difficult to sharpen?
I bet that's where the name comes from - it looks like it would be a proper nightmare to maintain.
It's a grind, the edge angles are all the same angle.
You guys are overlooking the main advantage of this grind; the appearance.
I find it badass.
The main bevels are ground at different angles for different uses. I would be willing to bet the edge angle are ground different as well to stick with the different purpose theme. The front thicker flat grind looks to have a edge bevel the same width as the thinner hollow grind area. A more obtuse edge angle would be required for that to occur.
A Nighmare grind is not really a grind, but a blade feature, like a recurve. The Nightmare grind is basically an additional grind that is done by Strider to some of their custom MSC or DDC models. It resembles a deep hollow grind taken out of the middle of the blade edge creating sort of a hook or recurve depending on how the grind is done. The Tom Brown Tracker knife from TOPS has a similar feature.
According to Mick Strider, the Nightmare grind is named as such because it is a Nightmare to Grind. Some of the nightmare grind models have two nightmare grinds overlapping, which creates a very unique look.
Allen Elishewitz's Horus and Anubis folder designs for CRKT both have what is essentially a Strider Nightmare Grind as well.
Cool story bro.
Recurve + Tanto = a nightmare to sharpen in my book, in any case.
My question:
Who has these two unique qualities:
1. Owns a nightmare grind Strider.
2. Is concerned about the actual difference in slicing quality between a full flat grind and a hollow grind on a piece of $500 sharpened .25" steel.
Sounds like that knife/grind was designed for the French Commando who likes his stinky cheese to be sliced newspaper print thin...
that knife would be gravy for me to sharpen. maybe an extra minute to change wheels.
To sharpern just use the corners of the stones on a spyderco sharpmaker.
