- Aug 30, 2007
I have a Sears 2X42 belt grinder and have wanted a scotch bright belt, but have not been able to find one. So i made a buffer out of scotch bright pads and a 4"X1/4" bolt 2 washers and 2 nuts. I cut out rounds the size of a soup can from the SB pads, punched a hole in them, put a washer on the bolt, threaded on about 8 of the SB rounds, added the final washer and then put on the first nut as tight as it would go and added the second nut as a stop to keep the 1st nut from loosening. I use my 3/8ths drill and run it over a 500 grit hand rubbed blade to give a real nice finish. I have struggled getting out fish hooks on my rubbed blades and the SB pads have solved my problem. Since I am doing everything on the cheap I do not have a benchtop buffer.
