- Dec 30, 2008
I do have some MAF cleaner as well
Fluids should be fine, ATF, oil etc. engine cleaner would more than likely be a no no, MAF as suggested may be fine, ether would probably be another bad one. But I'm sure some deposits on your hands wouldn't cause issues.
If you're using real compressed air (vs. canned air) nearly anything is going to be fine. I too would suggest staying the heck away from brake cleaner. If you need solvents (which I doubt), I'd use carb cleaner.
Just curious where the compressed vs canned air point comes from... My understanding was that compressed air (from a tank) tends to have a lot of moisture in it, unless you're running a dryer on the line, and that canned air has a lower moisture content. If that were the case, wouldn't using canned air vs compressed be better for the knife, as you're not blowing it out with moist air?
I could be wrong, so if you've got other info on the topic then I'm curious to hear.
I sometimes run a dryer on my compressor, but even if you don't, unless you're in some extreme moisture conditions, some moisture in air at 100psi isn't going to leave any moisture in the knife. My point about the canned air is that the pressure is so low that you're not going to get anything like the same kind of clean-out that you'd get with higher pressure air.
