So I've seen videos on backyard heat treating of O1 and have read on this forum that those instructions are pretty poor as O1 requires proper temperature control and hold times to achieve optimum performance. Without ordering from the USA or paying a lot for shipping, my only readily available supply of knife steel would be O1.
Suppose I profile a kitchen or outdoors knife out of O1, heat it up in the backyard until non magnetic and hold for 10 minutes (because some instructions mention it and might as well do it) and then quench in canola. It is then cleaned up and tempered twice in a toaster oven at the required temperature and time for the desired hardness.
For sure, this process will not achieve optimum performance but is it worse off than if I used 1084 or simpler carbon steels that don't require such precise heat treatment processes? My biggest concern is time and money. O1 is cheaper and more readily available in my area (Toronto, Canada). Also, I think O1 has more options in terms of available heat treatments as it will harden up on its own due to heat loss via radiation (magnitude of energy lost to still air is not on par with radiation until 350 °C and at that point, it is equal in magnitude to radiation).
Is there any drawbacks of not getting the most out of O1 especially when it is cheaper than other steels that are easier to work with? Thoughts? Comments?
