- May 19, 2018
Sweet! I will try to find a source. Thanks man!AllenKey they have it with cloth backing it is called RhynoGrip It comes in a roll. I have used it and really liked it.
So you like the film better than rhinowet? Where do you get it from? I suppose I could even get the belts and just cut those up, wonder how that would work!I’ll send you some 3m microfinishing film roll (which is what i mostly use) samples if u care to add to your write up comparison. I have Rhynowet as well but prefer the film roll which has a 5 mil backing.
As far as hardened steel, big big difference between high alloy steels and simple steels In terms of sanding and scratch removal.
I like the film backed rolls because it has a lot of versatility and uses. So I prefer them for hand sanding of blades as well as rounding the spine and choils.So you like the film better than rhinowet? Where do you get it from? I suppose I could even get the belts and just cut those up, wonder how that would work!
I use Rhynowet as well for such things as flattening scales.
Why is hand sanding taking you hours?
You should try norax ceramic, they very reduced my sanding time. Also dykem while grinding will help you spot the scratches. I almost exclusively work with 440C and CPM154, takes me about 2h total (hand sanding) to get a perfect satin at 600 grit on a 8" cpm154, because of this technique . But nothing will save you if you do a mirror finish xD another trick I do, if you are patient, grind to almost finish your bevel with 50 grit, then switch to norax x45 (about 220 grit), if there are scratches left, you won't miss them. The norax belt are a game changing for me, they last and last and last and last, and the finish they leave is wow, I mean will they ever die?Adam, I'm assuming it's not supposed to take this long, but i can't seem to figure out what i'm doing wrong, and how to speed it up. I spent 2 hours yesterday ~~ doing one side to 220. I started on one side to move up to 320, and didn't have anything left in the tank (so to speak). I think my issues is i create a lot of deep highs and lows when grinding (i'm very new) and must not be taking them out as i go up my belt grits. I come off the belt at a 600 or 800 trizact finish. How many passes do you all do before you climb to the next grit, i feel like i get a uniform finish - then do an extra pass or two, just to ensure.
The knives i was sanding had 60 grit scratches on the flats from surface grinding it (should have hit those up the grits on the grinder) and that added some time for sure, but it seems the bevel took just as long...
Thanks, I ordered a roll from ebay of the 30 micron (600 grit) to try, thanks for the pointer on this!I like the film backed rolls because it has a lot of versatility and uses. So I prefer them for hand sanding of blades as well as rounding the spine and choils.
Just out of curiosity, how do these compare to 3M wet or dry you get at the automotive store?
well I got the 3m microfinishing film roll in the other day... I can see how this would be REALLY handy (if it works well) for hand sanding... just unroll a bit, cut it off and use it on the sanding block. and yeah, I had an extra contact wheel I stuck in the 'arbor hole" that fit perfectly.
Getting a disk will make flattening very easy too, if I notice my hand sanding starting to reveal deeper scratches, I go back to the disc.
I have been desperately scrounging for a used one, but think it's time to just build new...
but they are so cheap.....a disc grinder is one of the best value items in a knifemaker shop.
$150 for the 3 ph motor, $100 for the disc, $40 for plugs to wire it up to your existing VFD.
I’ve never heard this. I’ve used my vfd to power 4 different machines all with different motors.I've heard it has to be the same motor that is currently alreadyh ooked up to the VFd to work.
