- Apr 12, 2009
The rubbing stones make a good base and they're pretty flat as well, but for serious lapping I've found failure to include a loose grit to result in some stone glazing, no matter how much water is used. Even a pinch or two of blasting grit will work wonders compared to the bare stone. Have heard the Simple Green works well too, and I used to use soapy water, but after trying oil for a while, I can't bring myself to use another method unless I have no choice. Other options work, or nothing at all if I'm camping or on the go or in a real hurry. The oil seems to keep the stone in the best shape and in my hands the best edge per grit value. Have heard the oil promotes breakdown of the binder faster than other choices, don't know if this is true but my stones all look brand new after much use - actually better than brand new. Keep your observations coming, I'm very interested.
HH
Just an idea, I have some emery cloth that might provide the loose grit. Also have a granite 'reference plate' (dead flat), bought at a Woodcraft store a few years ago, which could serve as the base for it. The emery grit comes off the cloth backing almost immediately after it's wetted, and I've often thought that could be useful for some 'instant lapping slurry' if/when needed. Might fiddle with that a bit. Might also put down a full sheet of wet/dry SiC sandpaper, under the emery cloth, to protect the granite's surface. The 'emery' should be corundum (natural aluminum oxide), which is very hard stuff at ~9 on the Moh's scale. Not sure if it's hard enough to abrade the SiC of the stone, but might serve to dislodge it from the binder, which would be ideal I'd think, for flattening (if it works).
I used the Fine side of the stone again this afternoon, to re-bevel the spey blade on a Case trapper (420HC). I actually soaked the stone in the sink (water), then spritzed it with a little Simple Green for the grinding. After a minute or two of that, when checking the edge of the blade, I just put the stone back into the sink of water, and then re-spritzed with the SG for the next bit of grinding. That seemed to work pretty well, and I'm not seeing any indication of the stone getting loaded at all (and did see a lot of the leftover swarf & such in the bottom of the sink, afterwards). I did do a little rubbing with the fingertip, while immersing the stone, to lightly rinse away whatever might be collecting on it. Officially, it 'needs more study'
David
