- Apr 12, 2009
I'm sure the finish on your ceramic will change toward finer 'feeling' (you cannot change the grit size). I used a lot of water when lapping mine and it took a lot off the diamond. Perhaps lighter pressure will help. At any rate use your coarse until it clogs then go to the fine until it clogs Twice rinse inbetween. Because the water becomes like plaster paris full of slurry. Scrap this off using a popsicle stick and with a small jar, save it for future use on a strop or other stone as it is good diamond slurry. Use perhaps 70-90 strokes each time. Let us know how it turns out. I went ahead and bought me another diamond stone to replace the coarse afterwards. It sounds like yours really needs it . Examine each side close, moving a straight edge down it while looking into a light to determine which is the most off and only do one side. Then mark it with a dot in the corner with a magic marker so you'll easily know which side to use for your razor. DM
David,
What brand/type of ceramic stone did you lap, with your diamond plate? Reason I ask is, your reference to the 'slurry' becoming like 'plaster of paris' sort of throws me. I haven't seen that much slurry come off of my ceramic hones, when I lapped them. Certainly not enough to totally clog the diamond hone. Just a little water on the surface of the diamond plate, is all I needed to keep the swarf flushed off. Maybe I'm mis-interpreting what you meant, but it does make me wonder.
Spyderco's grit size is constant, across the range (Med/Fine/UF) of their ceramic hones. They rely on the 'surface prep' of the hone, as finished at the factory, to determine the aggressiveness and the polish produced for each grit. I assume this is due to different binders for the grit, depending upon the grit range. This is why I cautioned as to which diamond grit to use, as it will change the (effective) grit, in terms of the final finish and performance.
Thanks.
