t1mpani
Platinum Member
- Jun 6, 2002
I recently picked up an old Edge Brand bowie that is in good shape (in terms of little or no use, no surface rust, etc.) but needs some general lovin' to bring it up to speed.
First up is the old stag scales have warped a tiny bit--still very solid but have left a noticeable gap at the mortise top and bottom. Also, the design of the guard is nice and robust, but up front it's a square cut notch that doesn't taper to follow the plunge of the blade grind, so there is--again--a large gap where moisture, dirt, animal fats/blood, etc. could get in to the tang. So, a couple of epoxy fills are in order.
My question is, would it be worth putting the whole knife into an oven at right around 215 deg. F for an hour or two to try and remove any moisture that might already have collected inside the handle? Am I just asking for even more warped pieces of stag?
I thought of just immersing the whole handle in a cup of mineral oil to displace moisture from the tang and also treat the stag, but am worried about how well my epoxy fill would adhere on the stag when I can't really get into either gap to get the oil off the gluing surfaces.
Any ideas would be most welcome, even if framed in a "just do the epoxy fills and stop making this so damned complicated" sort of way.
Warren
Warren
