- Jun 7, 2003
My brother drives a tow truck , he is often first on the scene of a crash ( the tow industry is kinda competitive where he is ) and has to do stuff like cut seat belts and help people out if their car looks like goin up in smoke , or cut the battery cables if its going to stop the battery smoking up because of a dead short ... somewhere in the crumpled wreck
other times he gets called to tow a car out of the sand or mud or from where its wedged in a tree or down an embankment , usualy this kind of call comes after 4 or 5 Good Samaritans have had a go and left their bits of tow rope knotted on the stuck vehicles tow points , he has to cut them off before attaching the chains to haul the car out
till now he has been using a high end folder I sent him thinking it would be a safe queen not a user ... and he mentioned that after doing this for a while , the blade has lost its shaving sharp edge ( wonder why ? )
I decided to make him a knife that he can abuse the daylights out of and not buggar up
so far this is what I have :
it took me a couple hours this afternoon with my trusty angle grinder to turn a Starret red stripe all hard hss blade into this .. well , I have a lot left over still so Im going to work out what to do with that too
I figure the saw blade cuts steel , like massive steel , so as a knife blade it should cut rope and copper cable easy enough .
the blade spine and but of handle are hopefully made so that he can slip the point under a rope knot with the spine against the tow point and thump the blade thru the rope when it is too hard to get under and slice the stuff off .
The blade is hopefully short enough that he can still cut a seat belt safely without hurting the guy / gal in the seat , and strong enough that he can basically abuse it like a ham fisted towie does and not bust it ..
I guess its not so much a knife he is depending on for survival , but others may well depend on him having a good knife for their survival even if they dont realise it .
Im open to suggestions for any changes . or ideas for the next one .
