Tsujigiri
- May 25, 2009
Here are a few, some pretty common or well-known but worth noting:
Tops/Buck CSAR has an oxygen wrench in the blade and holes to bend wires underwater. I've only been scuba diving twice, so I have no idea what that means, but it's apparently useful for the intended user.
Chris Reeve had a series of one piece knives made from a solid block of steel with a hollowed out handle that could be filled with matches, tools, etc, and then sealed shut. A lot of other companies have made hollow handle knives, but this one is actually a workable knife because it's a solid piece and won't break at the joint like the others do.
Since the Alkaid I posted earlier isn't readily available, I'll point out that We has something simpler and a little less impressive, but along similar lines. The Typhoeus is considered a fixed blade since the blade doesn't fold into the handle, but you can shift it between a regular knife and a push dagger. You can't lock it in either position, though, and the sheath is only set up to hold it as a push dagger, so it'll be obvious to people that that's what it is.
Alternatively, even simpler than that is the Brous Silent Soldier, which is designed so you can loop your fingers through the holes a few different ways, with one of them being putting your middle finger through both holes with the round butt in the palm of your hand, essentially making the knife a push dagger.
