- May 3, 2006
Does that hemlock pop in the fire a lot?
Yes, in fact, it poped a lot! There's 4-5 new holes in my tarp to prove it
Next time, I'll make the firepit a *little* further away...
I'm also into using saws for wood gathering. You might want to check out Silky Saws. I have a Super Accel 210 from them, 8 inch blade, 9.5 inches folded, and only weighs 9 ounces. It rocks.
Thanks for sharing your outing!
Great pics!
Do you know how cold it got overnight?
as for a flat tire, i always pack a small bike kit whenever i'm more than a mile from home. two tubes, tire levers, tire wrench (i don't have quick off tires), and a small pump.
those are good looking knives too, yours and the others...
So far, I'm very satisfied with this steel's performance. I used it to baton, for instance, full swing, several times in the last year or so. The convex grind makes it a pretty sturdy blade, and at RC59, it keeps an OK edge (I prefer ~61 for smaller blades). The only chipping I had, and it was tiny, was when I used a dirty stump as a chopping block...not smart. On the other hand, It was a bi*ch to shape with a file...I don't know if it is due to the CPM or just how well annealed the steel was, but give me PGround O1 (or PGround 154CM for stainless) to work from anytime. To answer your question, the very edge is finished with medium Lansky stone. I know, polished edges are more robust on big blades, but I'm lazy, what can I say... It makes this blade a convex grind with a V edge! The edge will be convexed over time, as I like to use sandpaper for on-the-field sharpening.
Thanks for your interest!
