I recently purchased a Grayman Satu, by anyones definition (even the knife makers) a hard use knife for sure. But I recently saw a post about CRK Sebenza's which are considered a premium folder not being hard use knives because the warranty would be void if the end user flicked it hard repeatedly. Here is the thread; http://www.bladeforums.com/forums/showthread.php/998088-Chris-Reeve-s-no-flick-policy So okay, I get that you can abuse a knife by using it beyond it's intended use and design function.
My Satu is a 10+ ounce chunk of steel and titanium but by scale it is no different than the Large Sebenza. Both use (or used) S30V Steel blade stock against a Titanium lock bar and while the Seb is smaller, by scale it is about the same as the Satu when you compare the size of the blade to the size of the lock bar, so by extrapolating, it seems to me that if you flick the Satu, it should do the same damage as flicking a Sebenza and subsequently void any warranty to replace a damaged lock bar or blade stop. I don't suppose you can exactly call a large Sebenza a hard use knife, but at about $400 a copy, it should be able to stand up to a whole bunch of flicking and hard cutting just like the Satu at about the same price.
So again, I guess what I am asking is what makes a folding knife a hard use knife? Does it need to use all steel components? Is it determined by size and if so where do you draw the line? Does hard use apply only to the opening and closing use? I think the titanium is a soft metal used for it's corrosion resistance and weight but would it's use exclude a knife from being a hard use knife?
There are some things that are obvious like hammering a blade into a tree and hitting it from the side with a sledge hammer to break the blade. I am exaggerating to make a point but where do you draw the line for what a hard use knife can do without voiding a warranty?
Probably a bit academic, but seems worth some conversation for a knife forum. Any thoughts?
