- Jun 11, 2006
I got the plans on sat and i have gone over them with a fine tooth comb and there is onley one thing i can say
IT'S SO EASY A CAVEMAN COULD DO IT
If your thinking about getting a set of these plans dont even think about it just do it. very very well'ley thought out. very discriptive and easy to fallow. i must say I think that this grinder will be probabley one of the best because its not welded so its very easy and quick to add or change it.
I do have a question though, in the motor section it says its designed for 1750 rpm motor but if you use a speed control on it you would still have to use a steep up pully to get a top speed of 4000 sfpm where if i used my 3hp dc 3500 rpm i would just use the same pully on each shaft and top speed would be around 4000. would this give me more tork at lower speed because the motor is running faster?
