O1, A2, D2 available
Feedback: +23 / =0 / -0
I have some O-1, 500lbs + forging stock coming in next week. Also I have available A2 and D2 in fixture sizes. If anyone is interested I will be selling it for $3/lb plus flat rate USPS shipping. Minimum order will be 10lbs one type or mixed. This is remnant and older stock with minor surface rust. It was precision ground but due to the surface rust it is no longer considered precision stock. As I said the O-1 is forging stock, sizes are .5 thick and up. Let me know if interested.
Sorry for my ignorance but could you explain what "fixture sizes" means?
Edit- aww crap, that means pommel and gaurd size pieces right?
No, this means they are thicker sized pieces used for making shoulder filing jigs dovetail fixtures etc. It is always nice to have heavier pieces of tool steel for making these. They are really expensive if you have to buy a full size pieces. If you wanted to mill the pieces down it they would work for blade material. If there is any thinner pieces I will list them.
Here is some pics of the O-1. If anyone is interested let me know how much you want and I will weigh it out. The sizes range from .5x10 to 1x2.Will make great forging stock. If anyone is interested in the A2 or D2 I can pick some of that up also.
Which one. I don't have any steel without rust. Oh I do have some 303 and 304. Is that what your looking for??:D:D If you really want the one with the least rust I will gladly set it aside for you. Once you stick it in forge though you really won't know the diff....
I think I would like some thicker O1. I really want to make a true integral. Are you going to give a list. Maybe i will get some 1x2 or some 3/4 by stuf thanks. Jim
How much do you want?? I have 1 piece of 1x2. Several pieces of 1x1 5/8. Kind of what are you looking for. maybe i really need to get a list together.
O1 is available in the following sizes
1x1.625x43.75.................. 1x1.625x57.875
1x1.625x19.5 ................... 1x2x30.125
.75x2.125x45.................... .75x1x41.5
,625x1x35........................ .5x2.875x19.25
.5x2.125x27.75.................. .625x3.375x31.25
.5x3.5x24 ........................ .5x4.25x14.75
.625x4.75x12.125 .............. .625x6x11.125
.625x7.125x7.75
There may be more than one of an item so please contact me if you are interested. I will cut to size and to fit into a flat rate box.
Thanks for looking
Chuck do you have any D2 in 1 1/2by 3 y 5 inche pieces? Tell me what it would cost to 73036. MIKE
I will be have to see if I can get that one. That's a chunk of D2... It will take me a bit before I can get back to you on that
Nice job your saw did on the 52100! :thumbup: Got the two rounds, the A2, D2, and O1 today. :D
Should keep me busy, if I ever get started...:rolleyes:
Thanks, Chuck!
Your welcome. I was so impressed with how accurate thet saw was when it came in I decided never to change it. I have cut.010 slices before just to see what it would do. No problems. Enjoy your steel.
Chuck, Just remember to bring it. Rust is no problem. Just being picky...... :D
Hopefully I can remember..They say memory is the second thing to go, Can't remember what the first thing is.:D:D Picky you never;)
