- Dec 31, 2008
Can you get a good hamon with O1? If so, please explain. Thanks.
Dustin - unless you are trying to show a transition line, I see no reason to edge quench. If that's what you're going for then yes, it will work for you. You may have to get a deep etch to show real contrast. If you just want a functional knife then I would through quench.
I understand where you guys are coming from but I respectfully disagree.
From what I understand Hamon means literally "blade pattern". Wavy or straight doesn't come into the picture for me.
You're right, it's all in what you're going for and what you like. I can appreciate the skill and technique it takes to do both but I don't feel one is inferior to the other.
Just my opinion, and you know what they say about those.
Later,
Iz
Give it a try and see what works best for you, I've never had a problem with through hardened blades breaking or bending. You may be surprised at the kind of regular abuse a large blade can take, even when not differentially heat treated. If you're trying to bend it back and forth like they do in the Ed Fowler video then you may want a soft spine, but if you want to chop, cut and bang around with it, I can't see any real advantage.
