O1 Heat treat failure.
made a first attempt at heat treating a blade made from O1 today and seem to have met with complete failure. after quenching and temper the blade seems no harder than it was before.
here's what i did. i really hope someone can tell me which part was wrong....
went in to work on my day off where we have a small heat treat oven, and brought a supply of vegetable oil with me.
i cleaned the blade and put it in the cold oven. then fired it up.
over about 20-30 minutes the oven heated up to 1475 F. i didn't hold at the pre-heat temp as the temp was rising slowly enough i felt the blade was probably heating evenly.
when the oven reached 1450 i started a timer and held the temp between 1450 and 1500 for 15 minutes.
after fifteen minutes i grabbed the blade with some tongs and very quickly moved it to the oil. there was about 5 quarts of vegetable oil that was heated to a temp of about 100 f. when i grabbed it from the oven it was glowing fairly brightly and was light orange color.
i moved the blade up and down in the oil to ensure even cooling till the blade reached 130 f. i did take it out once to check the temp with a non contact thermometer and it was about 350 f. put it back in immediately.
the blade shifted in my tongs a bit and a portion of the handle was sticking out on the initial dunk which caused a bit of flame but only briefly before it was submerged too.
as soon as it reached 130 f i wrapped in in AL foil and transferred it to a preheated toaster oven at 400 f for 2 hours.
my research seems to suggest two possibilities:
one is that the thermocouple on oven is royally screwed up and i didn't hit critical temp. the oven is older than old so it's definitely possible the temp reads incorrectly but my research suggests that the steel had the appearance of being near critical temp so almost zero change in hardness seems odd.
two is that my steel was mislabeled. i don't know of any way to check this other than to try spark testing it. if it's a some other type of tool steel this may be difficult to determine.
any thoughts are welcome as i really like the blade.
thanks
It would be better to post in the General Knifemakers Section of the forum to get an answer
