- Mar 19, 1999
I have read everything I could on these and other forums about heat treating 01 at home, I took a test piece today to practice on before I tried any of the knives I have made so far. I hung the test peice by a coat hanger from my garage ceiling, I then took a propane torch and started running it up and down the three inch section of steel, after about ten minutes, I never changed the color of the steel much past blue,brown black color, when i took the torch away, the steel looked like I hadn't done anything to it. I then held the torch on one section of the blade, and didn't wave it around at all just to see if I could get that little section hot enough, and I couldn't get it to turn red, after another ten minutes or so. My question is does it take longer then ten minutes to bring the steel up to temperature? Do I need a different torch, if so what kind? or was it that my garage which is very drafty, was way to cold,(30 degerees Fareheit). Any help would be appreciated.
Also here is my plan for the heat treatment procedure, any advice about whether I am going about things properly or not would be greatly appreciated.
step 1 heat blade with torch until it becomes red
step 2 drop into pot of olive oil that I previously warmed up on the stove until it is cool enough to touch,
step 3 throw it in the oven which is preheated to around 450 all the blades are 1/8" so i took a saw and cut a peice or 3/4 wood with a bunch of 1/8" slots in it, I figured I would put the blades in the slots spine down, so that they would heat more evenly,(can I just lay the blades on a cookie sheet, or is that bad)
step 4 while first blade is in the oven, start heating blade 2 with torch, quench, put in oven next to blade one.
step 5 once all blades(4-6) are in the oven let sit in there for about 30 minutes, turn off oven and open the door and slowly let the blades cool,
step 6 once blades are cool enough to touch, put them in my other preheated oven at 450 for about 30 minutes, take out and let cool, and put blades back in the first oven for 30 minutes at 450.
Am I doing everything right, will my wood block burn up in the oven? I need help guys, these are my first knives, and they kind of suck so I don't want to pay anybody to heat treat them for me, because they would laugh at my horrible grind lines, but I think I can make decent using knives out of them, and I would like to try. thanks in advance for any help, and sorry this is so long.
Kyle Fuglesten
Kyle Fuglesten
