- Jun 23, 2006
Good point - although I still don't feel that S7 is a "good" knife steel.
OK, now that we've seen that not only can I read the same data sheets you can, but I also own them, can we get on to the part where you show us properties in S5 that are desirable in a knife?
What I have been thinking about lately is having an open source knife makers project. What Im talking about here is keeping everything out in the open. Using FEA we could come up with different studies in hard use, kitchen use, skinning use, butchering use etcetc and use those models on a supercomputer to compare how different materials perform, how different dimensions perform etcetc. Before people dismiss FEA as being a "theory" thing it really isnt and there is airplanes / military gear / cars etcetc that are prototyped exclusively in FEA and have them pass rigorous real world tests just as the FEA study showed. FEA is a central part of modern design. I dont know if fellow knifemakers would be interested and it would be a big project but I think it could give us allot of highly useful information. There is so many different things we could try that having to build them all in reality is too limiting.
cheers
I really find it hard to track your thought process. One moment you dismiss comments on several years of testing and refinement of a process of heat treating a steel made by a pillar of the knifemaking community as being anecdotal and not worth spit and here you are asking for a whole bunch of anecdotal testing results. What gives?? There have been a number of instances where I've been reading your comments and I can't help but think, Troll! Maybe I'm overreacting.
I am interested to know what kind of hard use the knives are going through that they suffer from either serious deformation or shattering.
Have you looked at 3V for your hard-use knives? At your 58RC minimum, you are looking at 85ft lbs of impact toughness and a very high amount of wear resistance. In my opinion, this is a much more suitable "high-impact" knife steel.
When people bring up a good counter point and ask questions or ask for references, he seems to just ignore them.
I dont specifcally see what your objection actually is to doing a set of FEA studies - FEA results are in no way anecdotal, it is indeed used to crunch the numbers for coming up with highly accurate metrics.
if testing isn't done scientifically under laboratory conditions the results aren't worth spit and you dismiss them as being anecdotal.
Strength is an aspect of toughness. Strength is yield strength. My opinion is most knives need to be of a steel and HT that fails by yield strength, not plastic/elastic.
