Jason B.
- Jun 13, 2007
All right.
Sharpening knives and having nicer knives are a new thing to me, so I think I might be obsessively compulsively sharpening my knife(ves).
So my current setup is a norton India combo oil stone followed by a 1000/6000 grit king Waterstone, followed by stropping on jeans dry. I think I like it when my blades can push cut through paper, which I can get after the 1000 grit stone, but feels smoother after the 6000 grit.
My question is : how do you guys know when it's time to sharpen your knife???
For example, my Mora high Q robust blade... Two weeks ago, I did a little bit of wood carving. This past week, it got about an hours worth of cutting underground roots while I was fixing a lawn sprinkler system. And today, I put another hour of wood carving on it. In between, it's cut a few cardboard boxes here and there. I was able to steel the knife and get it back to fine push cutting of paper prior to foxay, but after today's wood carving - even after steeling - it only crumpled paper. I also noticed that near the end of my wood carving, the finer wood shavings became a little bit jagged and with rough breakouts here and there. I also saw that the bevel of the knife had a few little chips in it.
So I sharpened my blade again - with only the 1000/6000 stone.
Is this what I should expect? Do you guys sharpen your blades after jush 2-3 hours of wood whittling? Should I not worry about needing to push cut paper?
I'm trying not to be "that guy" that sits around sharpening knives all the time because of an obsession.
Or is this just inevitable, where resistance is futile, because Ive now joined blade forums?
I would say you are not maintaining enough and letting your blade dull too much which forces you to sharpen. I use a 1k and 2k-6k waterstones for most sharpening but I often maintain on the last stone used such as my Naniwa 2k. This allows the edge to stay at peak sharpness all the time instead of a gradual decline to butter knife status.
