- Apr 25, 2015
What are some of the more out there steels that you've seen out there or wanted to try on a knife.
Not so many rare steels that I want to try, but I would like to get some of the more common steels at varying hardnesses that are not commonly seen. For instance, I'd really like to try 3V at 59...
Add in some super accelerated quenches and some cryo to some low alloy steels at high hardness and I'd have enough knives to test and use for the next couple of years.
Farid Mehr uses more exotic steels..the current mini-K2 is D3. I've had it for a few weeks and I like it a lot. I'm not positive but I think it's finished at 60 hardness.
Hopefully it's not my last. I like what I've seen.
Yea, those little K2s are a great knife, I have been enjoying mine lots. I have a few knives in D3 and D6 from Farid. I have been pleased with them all. I also have a couple of his mules and a comp chopper in REX-121.:thumbup:
This^. Another thing you may run into is that above 60hrc I'd feel better with any steel if the spine was drawn back a bit-and some of the tempering temps and times we're talking about are so high I don't know how you'd get that to work in any reasonable way-not like you can go back in with a torch and draw the spine after regular tempering (at least in my knowledge.)Most production knives are tempered back way too soft for various reasons. You're probably going to have to go custom for most of the steels you mentioned at high hardnesses, but I think Survive! has their 3V run at 59 or 60Rc? That's a great level for general-purpose/"hard use" 3V... it improves the edge-retention and it's still very tough. :thumbup: I have all my 3V run at 60Rc these days.
There's a reason almost no one does that sort of thing... there's generally not much to gain from really fast quenches except breaking a lot of blades, and cryo just isn't required to get simple steels to form up into martensite properly (although I've never found any professionals who say cryo hurts low-allow steel, so it's worth a try for sure). All the low-allow steels can get good and hard (64Rc, some up to 66Rc, possibly higher?) with proper "normal" quenching techniques; final hardness is largely a matter of how far back you temper them.![]()
Pics, brother. Pics!He takes on some interesting steels for sure. The D3 chopper I have has been a superb blade. The steel has been nice to use on the folder as well, as you know.
I was also lucky enough to get a full flat ground mini K2, not many of those about.![]()
I'll take a few pics of the FFG K2 tomorrow, it's dark o'clock here just now.
D3 Chopper
REX-121 choipper
The thick one is the REX, the .25" is the D3.
A REX-121 mule doing its thing.....
