Why of why did I not find out about Cubitron belts earlier? Its.... its damn near orgasmic... the difference is amazing!
I've been messing 'round with inexpensive A/O belts for years. But, finally, I bit the bullet and purchased a bunch of high-end belts including some 36 grit Cubitrons. After a morning's worth of grinding I have produced 5 blades including an 11" beast of a chopper....... all on the same belt, and its still cutting like new.
Time will tell if this really does translate to a more economical method than using up cheap A/O belts at a faster rate.
Now.... grinding jigs.
I have a spinal nerve issue that has left my left hand without gripping strength and coordination. This means I have trouble with free-hand grinding - as in "I can't". My solution was to have a machine shop put together a jig to hold my blades. When I have a big, long blade I attach a long steel bar to my tool rest that provides ample surface for supporting the blade jig throughout the stroke.
I have yet to try this for hollow grinding( I have yet to try hollow grinding period). Assuming I can dial-in the height correctly I believe this may work, but my grinder has no means of adjusting the tool rest height.
Has anyone any experience with this process of jigged hollow grinding? If so, I'd love to get some tips on the process before I make the first attempt.
Thanks,
Peter
Here's my set-up:
There they are... 6 brand new Cubitron belts!! YEAHHHH!!
Thanks,
Peter
Here's my set-up:
