Is this method of scale attachment currently used if rivets are not opted for? If so, what year did inner frame screws replace adhesive? I collect only pre-1999 110s, and the newest ones I have sport rivets. My newest 110s without rivets do in fact utilize adhesive; which I favor over the method above. I want to order a ram horn scaled 110 without rivets, but only if adhesive is used. If the scales are going to be held in place merely by threaded nubs, I will then opt for rivets.
I know that you don't know. I am looking for an answer, not your assumptions. Please don't reply. It's as if you post just to post.
Hay guys,
After Buck_110's question I took a look at the last CS knife I ordered. It's a CS 112 NK Rammy, no pins. I looked at the inside and it looks like the back side of a rivet filling the holes, it sure don't look like a screw. However, I did the light trick where you hold the knife up to a light and I can see light coming through at both ends of the scales and a small spot of light coming through at the point where the back of the scale meets the side plate. It sure looks like no glue to me. I'll try to post some photo's. It would be nice if one of the Buck factory guys could give some info on this.
jb4570
A quick point on rivets...they do provide some "shear" protection against an impact to the inlay which might shatter the glue connection. Porous material like bone not so much as sealed materials like the impregnated birch...On the bad side if shrinkage in the inlay takes place against the anchor of a rivet sometime it will cause a crack.
On just the looks...Rivets could limit your ability of marking on the handle like scrimshaw etc...but sometimes they serve as almost a decoration breaking up a big bland handle
If I recall (I don't now have that knife with me at hand) mine looked like screws embedded from the inside. A CKS 110 Sambar Stag/ S30V made last August. I know in certain kinds of carpentry nails and screws are sometimes used to hold the thing in place until the glue sets. They are not then taken out. There is no light leaking through on my knife. A definitive answer from Randy @ Buck would be interesting.
I took a second look. Those are definitely screws.![]()
Can you elaborate? What kind of screw?
jb4570
