- Jul 13, 2009
To keep scale realistic, all things must match. The thickness at the spine, and the handle thickness and length are the most common wrong places. They often work out to be a 5/8" thick blade or a 2" thick handle, by scale. Use your micrometer while working, and keep removing material until the scale is right. An easy way of doing this is to use scales that are somewhat easy for your brain to convert. 10:1 is easy, as all you do is move the decimal a place.16" = 1.6".
25:1 is easy as all you do is read in mm and think in inches. thus a 36" sword with a .380" thick blade is a 36mm mini with a .380mm blade.
A higher layer count of much finer layers would have probably helped with this one.
