Oh lawd i need help!!!
Good day to all.
So, I am new into the whole knife making thing, so new i only made 2 blades till date (LAME), well here is the thing, the tools I have to my disposal is rather sad, but somehow still manages to produce something resembling a knife.
Now this bug bit me hard, and well I think I might be willing to fork out some cash here to set up something that would last a while until I can setup a pro shop once I have gained more practical experience.
So, I am looking at 2 small machines as a startup, which one would you guys suggest I get, bare in mind it is for bevel purposes.
Thank you all, and have a pleasant day
imgres
imgres
For bevels, all you need is a 2x72 grinder. As for a second machine, I'd get a big barrel. Use it to put all the money you're going to need to buy everything else. :)
i think you should buy a popular grinder if you are convinced its going to be a permanent thing. kmg is about the most affordable. somewhere around 1300. if you spend 500 on a grizzly or coote, soon you may want one of the big boys.
There are many others that come recommended by makers. 2X72, variable speed, 10"or even 12" wheel, flat platen, 220V or 110V, good brand name belts that you will wonder how come they wear out so fast and a lot of plain bar stock steel to practice on. So yah, a barrel full of money would help a lot especially if it was all in bills and not change.
Frank
What kind of budget are you looking at?
Ideally, you would get something like a 2x72, although they can get a little pricey.
You can always build a flat platen NWGS for about $250 to $500 depending on what you buy used, vs new. There's also the "sling" grinders by Polar Bear Forge (I think?) that you can build for $500 or less. The GIB kit they sell will be a little more money, but more versatile as well.
Can the sanders you listed be used? Sure, but I think they'll end up being more trouble than they are worth for what you're trying to do.
BTW, read the stickies at the top of this forum. They're a wonderful resource for new makers as well as old.
How much are you looking to spend initially in order to set up shop? Do you have ANY tools or a shop now at any level?
When budgeting, don't forget to include the smaller items and expendables. They add up fast.
