- Oct 1, 2002
Buy more knives!! You have an excuse!
I've had to reglue the shields on every single Queen I've owned. I have a stockman like pictured in this thread, the spring broke on the two secondary blades. I sent it off to Queen, and it came back "fixed", they replaced the spring, but it's so limp you can shake the knife and the blades fall open. The slightest touch moves them, like nearly zero spring pressure. It's sitting in my gun/knife junk drawer right now, trying to decide whether to see if they'd fix it right this time or just let it rust in peace.![]()
I just can't believe that. I have a Buck 110 (420HC) and it's NOTHING compared to a D2 Queen for getting an edge. And, it doesn't rust like the 110.
Seeing a trend here and rethinking Queen knives for purchase.....![]()
Queen made a great choice in D2 for the blades. But D2 would be overkill for a backspring, and needlessly complicated and expensive too. Grain & carbides are larger, which also increases chances of breakage in a spring. Edge-holding obviously isn't a consideration for a backspring either. On the other hand, a simple stainless like 420HC doesn't have the bulky carbides, and the steel is a better choice when corrosion-resistance and flexibility are the concern (lots of fillet knives are made with 420-series steels). For a spring it's the smarter choice, and much less complicated or expensive for a manufacturer to produce in quantity (less wear & tear on tooling).
420HC has both lower carbon and higher chromium. That combination gives greater corrosion-resistance than D2, which is optimized more for edge-holding (higher carbon) and wear-resistance (high carbon + chromium -> carbides) and some relatively decent corrosion-resistance in it's near-but-not-quite-stainless levels of chromium.
For what it's worth, I'd previously assumed Queen's D2 knives also had D2 springs. But in wondering if the springs would 'patina' in the same manner as their blades, I finally asked Queen about the springs. They were very clear and prompt in pointing out the springs were in fact 420HC. In retrospect, that really does seem to be the smarter way to do it, which confirms (in my mind) Queen's commitment to quality and smart design.
David
My apologies, Obsessed. I missed one word in your original statement and it made all the difference. I missed "backsprings". Yes, I agree those are not D2. That would be overkill. I stand corrected...and in need of glasses.
Great information Dave, as always, thank you for taking the time to explain that, I have little knowledge on the metals used, and this is a great help :thumbup:![]()
Right now I'm so broke I couldn't afford the postage. . :sorrow:
Update. The good folks at Queen sent me a new one. It was a full eight weeks, but worth it. The new one is not nearly as stiff as the original. And I had to put a better edge on each of the three blades. I love D2 for use, but that abrasion resistance becomes a real pain when it's time to sharpen...even with diamonds.
Thanks for tuning in.
Don't know the pattern number. D2 Stockman. Sorry
