Oil hardening Stainless?
I usually use carbon steel but have had a lot of stainless requests. Any stainless that is easy to harden and temper by just quenching in oil like O1? I do not have a heat treat oven. Thanks for your help.
Stainless can be oil hardened. I've oil harden 154CM in the past. The problem is massive flame up and possible warpage. If you don't have a HT oven you won't be able to do stainless. It has to soak at a certain temperture for a period of time.
Scott
Early in my Knifemaking I did not have a HT oven and I did alot of knives from O1 and used my cutting torches for heat treatment.
Later I experimented with 440C. I first tried to heat up the steel until it was orange hot and no longer magnetic. I held that temperature for about 5-10 minutes by moving the flame constantly over the entire blade to keep the heat even. There was some hardening, but it was not at all good enough.
I went back to my torches and held the orange hot temperature of the steel for half an hour. I added more fuel and less oxygen to the torch so that the flame was more white than blue to reduce the oxydation build up on the blades. In the end I had blades that were nice and hard, but had an awful thick build-up of crud to grind off. I tempered in the kitchen oven at 400F before grinding off the black oxydation.
I must say that it was a hit and miss method, but some of the knives were excellent edge holders.
Experiment with this abit if you have oxy-acetylene torches. After getting tired of grinding off the excessive build-up, I bought a Paragon HT oven and have been using it for over 20 years, and only had to change the elements once.
ATS-34, 154-CM, 440-C are a few. But respond well to forced air hardening, or plate quench. Really no need for all the smoke, flam, and fumes from Oil quenching.
I agree with Mike, plate quenching is the way to go.
Scott
Thanks guys. Ordered some 440c to mess with. I guess my next investment is a good oven.
