If power supply is a problem, go with a gas motor. A 5-8HP gas engine will supply the same power as a 3HP electric motor. You can even put the motor outside,in a little pump house like tiny shed building. Open the front to run the motor, when not in use,close and lock it to keep the elements and kids out.Run the exhaust through the mini-sheds roof. The hoses can be run through a small hole in the wall.It is best, IMHO, to use metal covered hoses. Ten foot hoses should allow plenty of room.
Stacy
