Oil Tempering
I use a heat bath for tempering. The only problem I had was a small fire when I spilled some oil on the flame because my very sloppy manipulation of the container when stirring the oil to make temp even. i was doing it outside, i was wearing gloves and I was doing it on a very non-flammable spot :-) I do it that way because I can control the temperature very precisely with my kitchen thermometer. I use sunflower oil because is cheap here. Soybean oil is cheaper but if it smokes, it stinks. I temper at 200C or less than that which is ok for the oil I have. I finish my french fries at about the same temp.
For cooking at low temperature I use a box with very thick styrofoam walls I scavenged from a molecular biology lab. i heat up cheap vacuum sealed beef to 65C in a pot with water and then transfer bag and water to the box.
It keeps temperature very well and I control it by checking every hour and reheating a cup of water taken from the box into the microwave and putting it back in.
Maybe I will try the trick with hot oil for tempering. Styrofoam melts at 240C so it is doable. I will try to find a suitable box. Long but with low volume, to use as little oil as possible. I will put the contraption in a big pot to contain the spill if it happens. This way I don't need a thing with a thermostat.
Not quite.... don't let yer stomach get the best of you, bud:p
I think Kevin is just pointing out that the low-tech guys may benefit from the even heat dsitribution and liquid conductivity of the oil temper as opposed to the quirks in most toaster ovens.
Rick
Thank you Rick for having my back and clarifying that I was talking about my preliminary tempers which are followed by a full, longer time temper once I have things zeroed in. Tempering still takes time even when the heat is quick.
