- Jan 31, 2009
Hey my fellow BF'ers
I recently bought a used car, a 2001 Mitsubishi Colt 1.3GL, which ive been very happy with so far. I usually do all the minor maintenance jobs myselfl, as ive done on all my previous cars.
Anyways, this week i was going to change the oil on the Colt for the first time.
I unsrew the oil filler cap, crawl underneath the car and unscrew the drain plug, like ive done a milliont times on other car brands. The first thing i notice, is that theres not much oil that comes out. Much less than a litre trickled out. This perplexed me, and i thought there was not enough oil on the car. Anyways, i change the oilfilter too, before went to fill it up again. Please note, that i checked the dipstick a couple of weeks ago and it showed oil at midlevel.
The manual states, that my model takes 3.3 litres of oil, so i was expecting it to take this amount. But it only took about a litre, then the dipstick showed it completely full. :?: :?:
Apparently, it didnt drain all the oil from the beginning. I made sure the car was level before i drained the oil, so i dont really understand it.
I drove a little trip, to make sure the car was warmed up before i changed oil, and after i filled it up, i started it again, revved the engine a couple of times, turned it off and let the oil settle for about 10 min before i checked the dipstick again. So my readings should be spot-on.
It dosent really make any sense, and the only thing i can think of, is that theres still oil to be drained, but i cant see how i should get it all out when ive done everything one should do.
Today i tried again after i got home from work, which is a 45km drive home. I parked the car (made sure it was level), let the oil settle and checked the dipstick which showed full. I open the drain plug carefully, expecting the hot oil to pour out, but nothing came out!
I even started thinking that i might have removed the wrong drain plug, but i mean, how many options can there be?? The plug is located at the right front of the oil pan, and the screw says: "OIL".
I even tried jacking it up from the rear to make the oil flow out, but to minimal effect.
Its really annoying me
, especially because i gave 90 bucks for 4 litres of oil (and ive already wasted 1 litre), and because its one of the simplest jobs. Ive never had any problems on my prior cars, so whats the deal with the Colt?
Any ideas to what might be the issue? Does i have to use some secret trick to get it done?
Regards, all
Regards, all
