I'm not sure if you're familiar with Tru Oil from Birchwood Casey. It is AWESOME stuff. It's most commonly used on figured, expensive, gun stocks. Here is how to use it.....just wipe it on!!!! With a cloth, finger, whatever. If you're wood is dry and porous, the TruOil will soak in, and you'll need to add another coat. Keep adding coats until the wood has been "sealed". Once the wood is sealed, the last coat will dry on top of the wood, like a clear varnish. Once you get to that point, and the final coat produces a nice even gloss shine on the knife, it's recommended you don't leave it like that. Take 0000 steel wool, and buff that down slightly to a satin, or dull, finish. You can do full on gloss, semi-gloss, satin, or flat, just by the amount of buffing you do after that last coat. After that, you can use your favorite wax, if you'd like. I love TruOil. Great product.
