although I think anybody should be hesistant to volunteer to be a "damascus expert", I will give my input as a dabbler in it who is in a continuous state of learning.
The 8670m is an L6 "alternative", not L6. It is a good steel but does not have the same behavioral characteristics, so much so that I know there are those here who can witness that I noted this stuff was not Champaloy or R.D.S. well before the cat was let out of the bag by Admiral that it was not.
That being said it is good steel, but one needs to recognize the differences when partnering it. O1 works great with L6 for heat treating but there seems to be some divergence from the 8670m.
I have found that if one wants a nice contrast and a mix that you can almost get a good weld just by stacking it and setting in the sun too long, use the Admiral 1075 and their L6 alternative. I have taken to using this when I do pattern welding demos because it will make me look like I know what I am doing everytime. Welds that I would double down on with other steels I have done a sigle pass with a han hammer at demos and found the billet entirely welded despite my gut feeling that it can't be.
Heat the 8670m to critical and allow it to air cool and you will get a hardness equal to any air cooled 10XX series. Do this with O1, L6 or many other steels and you will get a much more significant increase in hardness. Heat the stuff and quench it in oil and you will easily get a 65HRC. I can't find a curve on this exact steel but I would say that it should be close in heat treat to something like 5160, although I would not mix it with that steel, for personal reasons, and the contrast would suck.
If it helps, I am using the 8670m with 1095, 1084 or 1075 in applications that require my pushing the damascus farther than my more finicky favorite would sometimes tolerate.
