- Aug 6, 2007
OK, so i got to forging this 1084 1 inch wide 1/4 thick, forged out this nice middle eastern style, semi fantasy sword, forged out real nice but I brought it a BIT too close to final dimensions.....hard to break the hamer finish habits plus I am a steel miser. I started grinding on it and my grinding technique is basically :barf: still soooooo things got a bit on the thin side. Dimensions are about 26 inch blade length, with the Very base of the blade starting as 1/4 thick, but then tapering after about 2 inches to 5/16ths, then tapering for the rest of the blade about 1/8th of an inch. Point of balance, is already about 4 inches in front of where the guard will be, perfect for a sword, and keeping in mind I have to clip the rest of the barstock off the end there and then forge out the tang, it willstill be at, before the pommel or guard or handle are on about 6 or 7 inches out from the guard area. LIGHT AS A FEATHER TOO, while it feels great, whooshes when swung, fast as all get out I am nervous, in the end will it be too thin to actually cut anything? I am not so worried about warping in the heat treat i have that problem solved, I am just worried will it be basically a noodle when I am done with it? The geometry is a just barely conves edge, and the spine is also convex. I remember the thread on flex being about geometry and stuff not so much heat treat, If I can pull it off this sword will cut like THE DICKENS too. I realise when you make the blade you have to know what it will be doing to adjust the shape and geometry accordingly, this one just got a bit out of hand. I am just wondering, after the guard and handle and pommel are on will this sword not have enough blade presence to be an effective cutter? I will fine tune the hilt parts of course accordingly to get the point of balance at 4 or 5 inches, but even then with such a light blade will there be a problem? Here is some pictures(and trust me the pictures smooth out ALOT of poor grind lines
Overall
A shot of the base of the blade, it tapers VERY quickly, in only about 5 or 6 inches from 1/4 to 1/8th.
Basically a 26 inch filet knife......... OH gosh it feels so nice to hold, just moves effortlessly, light as can be.
Overall
