I have a couple beautiful old .22lr's, one is a 1979 Browning BL-22 (lever gun) which belonged to my uncle who I'm named after (he was killed by a DUI a few years before I was born) and the other is a much older Mossberg 151(b) semi-auto with a tube mag that was my great grandfathers. It was a Manlicher but the front part of the stock was missing so I finished it off about 8" shorter and cut the barrel down to 20" and re-crowned.
It's got a set of Tech-Sights on it (peep sights) and is my most accurate .22lr far outshooting all my modern .22's.
No modification necessary. If the rifle is functioning properly, you can manually extract and eject a live/unfired cartridge without first firing it. It did not leave the factory only able to manually eject after firing firing the cartridge. Sounds like you didn't so much modify yours as you repaired it. Sound like your sear engagement was off or the surfaces worn.I also modified mine to allow ejecting a live round from the chamber (surprisingly that wasn't possible factory, once chambered it had to be fired to clear it, a little work on the trigger/sear and you can hand cycle rounds.)
No modification necessary. If the rifle is functioning properly, you can manually extract and eject a live/unfired cartridge without first firing it. It did not leave the factory unable to manually eject without first firing.
The 151M-B/151M(b) was made from 1948-1954. The first 151Ms were made in 1946. Since serial numbers on .22Lr rifles were not required before the Gun Control Act of 1968 and because Mossberg did not use serial numbers on the 151ms, there is really no way to more precisely date the year of manufacture within the production date ranges without other paper work or knowledge of when purchased.Another very interesting thing about my gun, its from the '48-49 (I forget the exact year of production) but its got some factory date stamps in a few locations that say "1938". This particular rifle is very strange, almost like it was pieced together pre/post production. It also has no serial # (just to be clear NOT A REMOVED #, it was never given one).
...I do wish the ammo situation would get itself straightened out - I am somewhat hesitant about using up much of my stockpile....
