- Sep 26, 2008
Four days ago, I purchased this old 110 and the right hand stamp is a first for me. I have two different data sheets on 110's and one (Joe's) says it's a Third Version, Var. 9 and the other says Third Version, Var. 7.
"Third Version, Integral Brass Spacer/Spring holder, 9 variations
Variation 9 (1968-1970)14
Stamp: BUCK, u.s.a., Inverted, Right hand, 440C steel.
Blade/Butt rivets: Visible on both sides of bolsters, 2 rear, 1 front.
Inlay rivets: 2 (tiny)
Rocker rivet: Brass, maybe headed.
Sheath: Leather, black. B or C.
Packaging: 2 piece yellow box about 2 high-(1), Use and Care leaflet undated-(1), Attention leaflet orange-(1), **
_____________________________________________________________________________________________________________________________________________________
THIRD VERSION
{7 VARIATIONS}
1966 through 1969
-forged & stamped/blanked 440C blade steel
-.115" thick blade
-one liner(reads tip down)
-two liner(reads tip down)
-semi-hollow ground blades
-cast frames
-solid Macassar ebony scales
7th VARIATION
1969
identical to 6th variation, except right side of blade has BUCK, U.S.A.[two liner] stamped on tang which reads tip down "
Which is correct? At any rate, the knife is in really nice shape and no blade play at all in any direction. It came with what I believe is the correct sheath, although it's in near mint condition and may not be original to the knife.
So, were there 9 variations or only 7?
THIRD VERSION
{7 VARIATIONS}
1966 through 1969
-.115" thick blade
-cast frames
7th VARIATION
1969
