- Sep 25, 2009
90.00 Shipped. Paypal add 3%. I take credit cards. Authorize.net verified merchant.
Tough. Versatile. Multi-functional. Easy to operate. Like the soldiers its made for, the Olight M20 Warrior is a carefully honed weapon of war. The M20s rugged body structure, stainless steel striking bezel, blindingly bright strobe light, and multiple functions give it a strength and versatility never seen before in the hand-held lighting market. The M20 Warrior is all the lighting tool you need in the battlefield or on the job. Bright, rugged, and flexible, the M20s multiple output levels and modes lend it a versatility and durability that make it the ideal tool for any task. The M20 Warrior is also a great choice for personal protection; the blinding light and crenellated striking bezel on both ends give added effectiveness when used for self-defense.
Specifications
Output
7 lumens, 150 hours
90 lumens, 12 hours
250 lumens, 4 hours
Strobe
Batteries: 2xCR123A, 2xRCR123A, 2x16340, 1x18650, or 1x17670
Dimensions: Length - 140mm/5.5", Bezel diameter - 33.5mm/1.3", Body diameter - 24.80mm/0.98"
Weight: 120.50g (without batteries)
Accessories: Holster, lanyard, two spare o-rings, spare fluorescent rubber boot, battery magazine
Features
World-class super bright Cree XR-E R2 (Premium)
Throws 250 meters
Tactical momentary-on forward switch
Three digitally controlled constant brightness levels and strobe
Auto memorization of specific function for instant access
Linear functional adjustment for easy change of functions
Front removable stainless steel striking bezel and rear striking bezel, removable for daily use, installable for close quarter combat
Superior heat sink that disperses heat to protect LED and electrical components
Ergonomic design with solid structure for easy operation
Full orange peel reflector and perfectly centered light source for flawless beam with the longest shot
Rugged indestructible aluminum body with anti-scratching type III Hard Anodization
Cutting-edge reverse polarity protection, with the right batteries, you can leave them in the wrong direction for extended period, it will not burn the circuit
Strong lanyard with quick release for easy access
Mil-spec: MIL-STD-810F
Water proof
Anti-shatter, anti-scratch, anti-slip ultra clear lens
Lock-out function to prevent accidental activation
Metal cigar hold ring optimally positioned to offer additional anti-roll properties and is pre-installed but removable for smoother body hold
Engineered anti-slip body texture to give you a firm, tight grip
Built-in steel pocket clip
Advanced digital power management system for constant, even brightness through entire battery life
Battery magazine to prevent 2xCR123A batteries from rattling in the battery tube
Specifications
Output
7 lumens, 150 hours
90 lumens, 12 hours
250 lumens, 4 hours
Strobe
Features
Throws 250 meters
Water proof
