Olight S10R Baton rechargeable 400 Lumens
Feedback: +85 / =0 / -0
BNIB
Conus
Paypal
$49.00 Net
Key Features:
NEW Low-profile side switch featuring a battery power indicator, which glows red when battery runs low
NEW Includes patent-pending Micro-USB charging dock and a 650mAh RCR123A rechargeable battery
NEW Thermal management safety program provides overheating protection by dropping high output by 50% after 4.5 minutes of constant on.
NEW Glow-in-the-dark o-ring in bezel to help locate flashlight from accidentally dropping it
99% light transmittance rate through tempered glass, with two-sided anti-reflective coating
Multi-function side switch with four brightness levels, plus a strobe mode
Automatically return to your last brightness level with the built in memory function
Removable two-position pocket clip
Flat tailcap with strong magnet, giving you the ability to use the light as a hands-free worklight
Highly reliable 6061-T6 aluminum alloy structure with ant-scratch, Type-III hard anodizing with a stainless steel bezel to protect against drops
Reverse polarity protection to prevent improper battery installation
Can be powered by one non-rechargeable CR123A lithium battery as a last resort in an emergency.
Low standby current below 8uA
Technical Specs:
MODE 1 MODE 2 MODE 3 MODE 4
400 lumens 85 lumens 5 lumens 0.5 lumens
0.8 hrs 3.5 hrs 56 hrs 168 hrs
341 ft / 104m
2,700 cd
IPX7 (waterproof up to 1 meter)
5 ft / 1.5m
1 x Cree XLamp XM-L2 Cool White
1 x 650mAh 3.7v RCR123A rechargeable lithium battery
Body: 2.89 in / 73.5mm Charging Dock: 2.17 in(55.1mm) x 1.97 in(50mm) x 0.63 in(16mm)
43g/ 1.52 oz (body excluding batteries), 24g/ 0.85 oz (charging dock)
0.9 in / 23mm
