Olight s20r flashlight bundle
Feedback: +15 / =0 / -0
I have an olight s20r bundle that I would like to sell for $50 shipped payment via paypal and shipping CONUS. It includes the flashlight, a 2600 mAh 18650 battery, the charging base, a micro usb cable, a lanyard, and a spare o-ring. I have carried the light and used it but it shows very little sign of any wear. The light functions perfectly. It is waterproof, shock resistant and Has a glow in the dark ring inside the bezel. It has a max output of 550 lumens. It has a high, med low and moonlight setting as well as strobe.
Here is a more in depth description:
The S20R Baton is an extremely compact and powerful LED flashlight with an intelligent multi-function side switch. Made from hard-anodized aircraft-grade aluminum, its low profile and high output make it an ideal all-purpose light. The top-of-the-line CREE XM-L2 LED puts out a retina-scorching 550 lumens, with a total of four different power settings and a strobe mode to suit your specific needs. And with its included rechargeable lithium-ion batteries and compact Micro-USB charging dock, you don't have to worry about bulky chargers or special cables. Plus, you can charge your mobile device via the USB port at the same time as charging your light through the Micro-USB port. The S10R also features a power indicator located around the side switch, which will glow red when your battery power is low. With it's dual purpose magnetic tailcap, you can use the S20R as a hands-free worklight, and attach it securely to the included charging base.
Glow-in-the-dark o-ring in bezel to help locate flashlight from accidentally dropping it
99% light transmittance rate through tempered glass, with two-sided anti-reflective coating
Multi-function side switch with four brightness levels, plus a strobe mode
Highly reliable 6061-T6 aluminum alloy structure with ant-scratch, Type-III hard anodizing with a stainless steel bezel to protect against drops
Enhanced shock-proofing in battery contact springs to support both flat and tabular 18650 batteries
Reverse polarity protection to prevent improper battery installation
Can be powered by two non-rechargeable CR123A lithium batteries as a last resort in an emergency.
Low standby current below 15uA
