busterbones
- Apr 16, 2005
Omega custom traditional bow NEW! $425 shipped
model Imperial
40lbs at 28in
"Initially designed to be a tournament legal stealth D bow, this bow turned out to be a hard hitting longbow that is at home in the woods as it is on the range! Stable and fast, this bow has less hand shock and greater stability than the Original. The long oak riser holds steady on target and is balanced to point naturally and the highly reflexed limbs deliver great speed with low shock while resisting twist. The aggressive D/R limbs pull straight into a D shape with no visible reflex, making it legal for competition. The long sight window is cut in a straight line to center to comply with regulations while remaining forgiving of a wide range of arrow weights and spines. Built with the same laminated oak riser and hickory limb core, this bow will last and carries a LIFETIME WARRANTY."
model Imperial
40lbs at 28in
