- Jan 25, 2013
If you torque down a 275 clip enough it would fit but you will have slop because of the larger hole size. If you have an 810 you can use the clip from that model as the diameter is the same on all other models. Make sure you use the existing clip screws on whatever knife you are replacing the clip on as the length does vary and can potentially interfere with the blade path or the liners.
